查看: 2866|回复: 0
ANSYS流体分析
发表于 2005-8-16 15:32:47 | 显示全部楼层 |阅读模式
ANSYS流体分析
在作ANSYS流体分析时出现以下的警告。
  *** WARNING ***                         CP =       9.328   TIME= 16:13:12
Old FLOTRAN results file exists, but contains different number of
nodes.  File will be renamed <jobname>.rfo.  The analysis will be run
as a new case.  To interpolate results from a previous file use a
FLDA,REST command.
*** ERROR ***                           CP =       9.328   TIME= 16:13:12
Error attempting to back up unuseable results file.  Check READ/WRITE
permission.  File.rfo.
*** ERROR ***                           CP =       9.422   TIME= 16:13:17
Error While building flotran data object.
是我的那部分出问题了??我看不明白了!!
okok.org
请各位版主、 高手指点迷津呀!!万分感谢!!
