查看: 2083|回复: 0
[求助]9.0中使用distributed ansys进行并行计算应该如何设置?如何修改文件?
发表于 2006-2-15 06:17:31 | 显示全部楼层 |阅读模式
请教ansys并行计算如何设置文件!
帮助文件如下中所说的文件在哪里?怎样设置?
For csh or tcsh shells, add the following line to your .cshrc, .tcshrc, or equivalent shell startup file:
source /ansys_inc/v90/ansys/bin/confdismpich90.cshFor sh or bash shells, add the following line to your .login, .profile, or equivalent shell startup file:
. /ansys_inc/v90/ansys/bin/confdismpich90.shAs a test, rsh into all machines in the cluster (including the master) and verify that the ANSYS90_DIR and the LD_LIBRARY_PATH are set correctly.
请高人详细指点~~
