查看: 3297|回复: 2
[求助]有人用过hypermesh吗?如何安装hypermesh5.0和ansys7。0我的lisence老是出
发表于 2004-3-30 18:39:04 | 显示全部楼层 |阅读模式
发表于 2004-4-5 15:46:05 | 显示全部楼层
[求助]有人用过hypermesh吗?如何安装hypermesh5.0和ansys7。0我的lisence老是出错 (无内容)
7.0的安装
1. Open ansys.dat in the crack directory and change "name" to
   your computer name and "000000000000" to your computer hostid.
   Run the keygen.bat which will create a license.dat.这里把license名字改一下,我改的是license1.dat
2. Run setup and install Ansys 7.0 and choose custom install
   and select all options.
3. At the end of the Ansys installation you be prompted to
   install the License Server. Install the License Server as a single
   server. When prompted for a license file, point the browser
   to the license.dat in the crack directory.
4. Read the documentation in the help for post configuration of
   CAD connection and Pro/FEA.
4. Reboot and run the program.
其它照这个做!
发表于 2004-7-2 16:48:36 | 显示全部楼层
我试过用ansys6.1和hypermesh5.0,不过只能用一个,另外一个就不能用,我也不明白为什么只能用其中的一个,而且改了hypermesh的lisence,ansys的就会自动跟着更改!!!
