查看: 6022|回复: 2
[讨论]用ANSYS11.0进行双向耦合的求解过程中所出现的问题
发表于 2008-2-20 22:50:37 | 显示全部楼层 |阅读模式
| ERROR #002100061 has occurred in subroutine SERVE_CLIENTS.         |
| The connection between this CFX process and an external process    |
| has died unexpectedly.  The following error was received:          |
|   External process  : ANSYS                                        |
|   Error experienced : Read                                         |
| ** This error is fatal:  Terminating ANSYS CFX Solver execution ** |
| Please review the output, error and log files from both the CFX    |
| and external processes to determine the cause of the error.        |
|                An error has occurred in cfx5solve:                 |
| The ANSYS CFX solver exited with return code 1.   No results file  |
| has been created.                                                  |
End of solution stage.
| The following transient and backup files written by the ANSYS CFX  |
| solver have been saved in the directory                            |
| F:\0212\0217\0220wanshang_001:                                     |
| 0_CS_full.trn                                                      |
| ANSYS Solver terminated with return code 256                       |
| The results from this run of the ANSYS solver have been written to |
| F:\0212\0217\0220wanshang_001.ansys                                |
| The following user files have been saved in the directory          |
| mon        |
This run of the ANSYS CFX Solver has finished.
  描述:我模拟的是一根弯管在内部高速流体运动下所产生的振动问题。用的方法是       ANSYS11.0软件双向耦合的方法
        总是在求解过程中出现这样的错误。
        希望高人能够指点一下! 谢谢了!
        欢迎讨论!
发表于 2010-5-21 20:22:37 | 显示全部楼层
同样呀,我也遇到一模一样的问题!
这为朋友你好,我在用ansys12.0做流固耦合时遇到与你完全一样的错误,不知道你的问题解决了没有,怎么解决的,希望指导,非常感谢呀!我为了这个错误都搞了5天了,一直没解决呀!
[ 本帖最后由 没什么不可一 于 2011-5-13 21:24 编辑 ]
发表于 2011-6-3 12:59:42 | 显示全部楼层
可能是网格变形过大产生了网格畸变,求解终止
