查看: 2773|回复: 0
ansys中建模型时用subtract时出现ERROR,初学者请各位大虾帮忙解答
发表于 2004-12-6 15:31:27 | 显示全部楼层 |阅读模式
建模型时,用一立方体减去里面我建好了的ADD过的比较复杂的型面,出现如下错误提示:
The following entities do not support booleans.
Use the SPLOT command to examine bad surfaces/areas
Format for SPLOT is SPLOT,NA1,NA2,NINC,MESHSIZE
        Volume      Shell     Area       Loop      Line
             1         1       542         1       346
             -         -       570         1       324
             -         -       643         1      1324
             -         -       671         1       477
             -         -       719         1       154
             -         -       720         1       132
             -         -       730         1       204
             -         -       731         1       226
             -         -       770         1       561
             -         -       772         1      1503
             -         -       787         1       669
             -         -       789         1      1521
             -         -       790         1      1520
不知问题出在哪里?请赐教~
