查看: 1692|回复: 0
请各位ansys高手来看看这ansys个问题!
发表于 2005-2-2 15:06:39 | 显示全部楼层 |阅读模式
各位高人:我怎么一装ansys8.0时它就出现下面这个问题呢?
notes to connection users:
  warnning -connection for unigaraphics:the unigraphics root directory(ugii-root-dir)must be appended to the system path .this must be done manually  prior to running to connecyion for unnigraphics product.
  connection for Pro/e :you must first run the the ans-admin utility to configure the connection for Pro/e.
请大家帮帮我啊!
