查看: 4567|回复: 1
[求助]CFD-RC一直出现错误的讯息
发表于 2008-6-12 01:42:20 | 显示全部楼层 |阅读模式
为什么用AC模拟老是出现这个讯息:
Error : Unable to open the DLL : libUserAce.dll
  Aborting the Program.
  There are a few reasons why this may have happened:
  1) You have mistakenly activated the  UBOUND
     user subroutine. If so please double check the
     settings in CFD-ACE-GUI.
  2) You have not yet built your user subroutine.
     Please make sure you compile with build-userlib
     utility script.
  3) You have not given the correct user subroutine
     DLL name on the RUN page of CFD-ACE-GUI. Please
     double check.
  If none of these solve the problem, please contact
  CFDRC Customer Support via email to support@cfdrc.com.
  Error Exit from CFD-ACE-SOLVER
不知道要怎么解决,我用的模组是Flow、Chemical
发表于 2008-6-14 23:23:14 | 显示全部楼层
[求助]CFD-RC一直出现错误的讯息
这个问题我以前遇见过别人碰见过,星期一我帮你问一下这个人,然后给你会一下
