查看: 3203|回复: 0
fastran跑不起来呀?高手看看什么原因!
发表于 2005-7-6 10:44:15 | 显示全部楼层 |阅读模式
hhhhhh.DAT
GUI >Version: v2003.0.0
FASTRAN >Version: v2003.0.0
                             FASTRAN Model Name
                             Problem Title
hhhhhhh
                    Additional Problem Information
                        Problem Specifications
  NZONES NCYCLES STEADY NEWRUN AXI-SYM OVERSET
      1 100 1 T F 0
                      Function Definition/Timing
  MOTION_MODELS START_TIME END_TIME PLOTF FORCE_SUMMARY
      0 0.000D+00 0.100D+03 1 0
  MONITOR_POINTS FORCE_BY_SECTIONS
                          Cycle Control Flags
  CYC/SOLVE CYC/PLOT CYC/CHIMERA CYC/6DOF CYC/RESTART
     1 1 5 1 1
                          Tolerances/Debug
  TINY BIG GEOMIN CONVERGENCE
  0.100D-19 0.100D+21 0.100D-19 0.100D-19
                          Tolerances for Chimera Hole Cutting
EPSILON_DIST EPSILON_AREA EPSILON_RATIO
  0.100D-13 0.100D-04 0.100D-04
                         Thermo and Transport
Gas_Model
Mol_Weight Ratio_Specific_Heats Prt_Lam Prt_Turb
  0.290D+02 0.140D+01 0.700D+00 0.900D+00
Vis_Model Suth_Coeff1 Suth_Coeff2 Dyn_Viscosity
      1 0.146D-05 0.112D+03 0.171D-04
                    Zone Control
Zone-Order Iterations CFL_Start/dt CFL_End/dt Nitcfl
      1 10 0.100D+00 0.100D+01 100
                           Zone 1
Zone Grid_type Chimera_type Moving T_scheme N_stage Inner Inntol
    1 1 0 0 6 1 10 0.100D-03
Ivisc Flux S_scheme Limit_N Limit_L Entf_L Entf_N Kappa
    3 2 4 7 7 0.200D+00 0.200D+00 0.333D+00
Init Re_init
    0 1
U V W p T
  0.20000D+02 0.00000D+00 0.00000D+00 0.10132D+06 0.30000D+03
k||n e||w Tint
  0.00000D+00 0.00000D+00 0.30000D+03
Mixture Number
  0.10000D+01
                                  Monitor Points
Number_of_Monitor_Points
Point_Number Zone_Number I_index J_index K_index Cell_Number x y z
          1 1 1 1 1 0 0.000000E+00 0.000000E+00 0.000000E+00
Error Exit from CFD-FASTRAN
CFD-FASTRAN Error Number : 25
GET_BLOCKAGES: WARNING
Original Blockage array not detected
using default values of 1
******* Grid Zonal Parameters
--- Zone 1
nface (OBFAC) -4
nface (INTERI) 0
nface (BOUNDA) -4
nface (TOTAL) 2
ncell (TOTAL) 1
nnode (TOTAL) 0
                              GRID INFO FOR ZONE # 1
  Grid Type: Quadralaterals/Structured
             I-Dimension J-Dimension K-Dimension Cells
                   0 0 2 1
--- Allocating and Reading IBOUND and QBOUND
*** Allocated 0.000 I-MWords for BC Arrays
*** Allocated 0.000 R-MWords for BC Arrays
*** Initializing Zone 1 with Freestream
--- Allocating Q, XYZ, AREA, VOL
     Allocated 0.000 R-MWords for Zone 1
--- Allocating IBLANK, IFPOIN, ICPOIN, IFCELL
     Allocated 0.000 I-MWords for S-Zone 1
*** Allocated 0.000 R-MWords for Grid Arrays
*** Allocated 0.000 I-MWords for Grid Arrays
