查看: 3192|回复: 0
[原创]动网格用remeshing,频频报错~~高手请进~
发表于 2007-9-30 01:10:20 | 显示全部楼层 |阅读模式
[watermark]动网格用的remeshing,iterate的话只能进行34步,然后无论是改亚松弛因子(四个数据分别设成0.2  0.5  0.5  0.5),还是改克朗数,或者把limits中的压力、温度都设成上限,还是提示错误,如下:
Updating solution at time level N... done.
physical-dt 9.1267e-005
Updating mesh at time level N...
Info: Maximum Cell Skewness outside reasonable limits, using 0.95 instead.done.
  iter continuity x-velocity y-velocity z-velocity     energy          k    epsilon     time/iter
    68 5.4947e+04 1.0236e+05 1.9865e+05 2.1381e+05 4.2887e+06 1.1625e+00 2.1180e+02  0:00:00    2
reversed flow in 23 faces on pressure-outlet 20.
reversed flow in 765 faces on pressure-outlet 19.
reversed flow in 39 faces on pressure-outlet 12.
reversed flow in 3 faces on pressure-inlet 13.
time step reduced in 262 cells
absolute pressure limited to 1.000000e+000 in 32 cells on zone 3
absolute pressure limited to 1.000000e+000 in 34 cells on zone 5  turbulent viscosity limited to viscosity ratio of 1.000000e+007 in 1 cells
Error: Floating point error: invalid number
Error Object: ()
请教高手,这是怎么回事呢?压力的limits我都设成上限了啊。
拜谢!预祝十一愉快![/watermark]
