查看: 3350|回复: 0
一个动网格的问题:Error message from graphics function Update_Display
发表于 2007-10-20 14:20:06 | 显示全部楼层 |阅读模式
用udf做了一个类似风洞的问题
物体用udf定义运动
结果在保存动画的时候
出现
动画不能显示
有没有遇到同类的问题
希望先知看看
Error message from graphics function Update_Display:
There was an unexpected Hoops internal error -
Update requested with update in progress!
"mpeg_encode  param1"
MPEG ENCODER STATS (1.5b)
TIME STARTED:  Mon Oct 15 07:45:46 2007
MACHINE:  unknown
FIRST FILE:  ./pz0_2_0000.ppm
LAST FILE:  ./pz0_2_0201.ppm
PATTERN:  i
GOP_SIZE:  12
SLICES PER FRAME:  1
RANGE:  +/-8
PIXEL SEARCH:  FULL
PSEARCH:  EXHAUSTIVE
BSEARCH:  CROSS2
QSCALE:  8 8 8
REFERENCE FRAME:  ORIGINAL
ERROR:  Couldn';t open input file ./pz0_2_0000.ppm
Removing frame files ...找不到 f:\fluentinstall\101422end\pz0_2_0000.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0001.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0002.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0003.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0004.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0005.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0006.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0007.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0008.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0009.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0010.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0011.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0012.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0013.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0014.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0015.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0016.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0017.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0018.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0019.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0020.ppm
done.
"mpeg_encode  param2"
TIME STARTED:  Mon Oct 15 07:46:30 2007
MACHINE:  unknown
PATTERN:  i
GOP_SIZE:  12
SLICES PER FRAME:  1
RANGE:  +/-8
PIXEL SEARCH:  FULL
PSEARCH:  EXHAUSTIVE
BSEARCH:  CROSS2
QSCALE:  8 8 8
找不到 f:\fluentinstall\101422end\pz0_2_0021.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0022.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0023.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0024.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0025.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0026.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0027.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0028.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0029.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0030.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0031.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0032.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0033.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0034.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0035.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0036.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0037.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0038.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0039.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0040.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0041.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0042.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0043.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0044.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0045.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0046.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0047.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0048.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0049.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0050.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0051.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0052.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0053.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0054.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0055.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0056.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0057.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0058.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0059.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0060.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0061.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0062.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0063.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0064.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0065.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0066.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0067.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0068.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0069.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0070.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0071.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0072.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0073.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0074.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0075.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0076.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0077.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0078.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0079.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0080.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0081.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0082.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0083.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0084.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0085.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0086.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0087.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0088.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0089.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0090.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0091.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0092.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0093.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0094.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0095.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0096.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0097.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0098.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0099.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0100.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0101.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0102.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0103.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0104.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0105.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0106.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0107.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0108.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0109.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0110.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0111.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0112.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0113.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0114.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0115.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0116.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0117.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0118.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0119.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0120.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0121.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0122.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0123.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0124.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0125.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0126.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0127.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0128.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0129.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0130.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0131.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0132.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0133.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0134.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0135.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0136.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0137.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0138.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0139.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0140.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0141.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0142.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0143.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0144.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0145.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0146.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0147.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0148.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0149.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0150.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0151.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0152.ppm
找不到 f:\fluentinstall\101422end\pz0_2_0153.ppm
done.
动画显示失败
