查看: 5050|回复: 9
using finite element method to solve fluid-structural interaction problems
发表于 2009-5-6 09:25:10 | 显示全部楼层 |阅读模式
I am trying to dig a pit here for the folks to post new or their own thoughts about the methods and the problem to be solved or the future of the fluid-structural interaction problems.
I am working on the finite element method for both domains.
welcome to discuss here!
[ 本帖最后由 foxgene 于 2009-5-6 01:26 编辑 ]
发表于 2009-5-10 05:25:25 | 显示全部楼层
it's not trivial. are you talking about writing your code, or coupling existing fluid/structure codes?
 楼主| 发表于 2009-5-11 13:23:18 | 显示全部楼层
I am writing my own code using least square finite element method
 楼主| 发表于 2009-5-11 13:25:30 | 显示全部楼层
How do you guys think about the coupling method. How about ALE?
发表于 2009-5-11 18:34:09 | 显示全部楼层
ALE精度太差,我手头就有,没有用它
 楼主| 发表于 2009-5-12 13:16:29 | 显示全部楼层
回复 5# onesupeng 的帖子
你有ALE的code么?
能否分享
仁兄用什么方法做耦合?
发表于 2009-5-13 00:07:27 | 显示全部楼层
ALE的code坦率地说有两套,版权不是我自己的
 楼主| 发表于 2009-5-28 02:20:25 | 显示全部楼层
发表于 2010-9-8 22:40:42 | 显示全部楼层
能否问一下楼主硕士阶段做的什么研究?
发表于 2010-9-30 12:58:23 | 显示全部楼层
没有了下文了?
