查看: 2595|回复: 0
ANSYS10.0在流体计算中遇到的问题
发表于 2010-5-21 20:51:07 | 显示全部楼层 |阅读模式
最近在进行流体分析时发现有以下问题出现,请各位高手指点:
  *** ERROR ***                           CP =     154.500   TIME= 20:18:56
Negative or zero temperatures may be avoided by either mesh refinement
or modified inertial relaxation especially if Petrov-Galerkin
formulation is used for the energy equation(FLDA,ENRG,SUPG,T).
*** ERROR ***                           CP =     154.625   TIME= 20:25:27
Negative or zero temperature detected.  This may be caused by a
diverging solution or by an incorrect temperature or property value.
A temperature offset may also be required.  (TOFFST)
  Node = 343047.
补充:温度场施加应该没有问题,问题还会出现在哪里,还望不吝赐教
