查看: 3993|回复: 1
用shell63单元分析简支梁振动频率出错!!!
发表于 2010-6-16 18:15:12 | 显示全部楼层 |阅读模式
我用shell63单元分析一简支梁的横向振动,shell63的关键字设置为keyopt1=2,即指考虑弯曲刚度,在solve时
出错——‘There no active degrees of freedom’!!!但是若将关键字设置为keyopt1=0,即同时考虑弯曲和膜刚度,计算结果没有问题,不知是哪里出了问题??????请各位专家指教!!!我写的程序如下:
finish
/clear,nostart
keyw,pr_set,1
keyw,pr_struc,1
*set,num,199      !沿梁长度方向划分的单元数量
/prep7
et,1,shell63,2      !keyopt1=2表示只考虑弯曲刚度-bending stiffness
r,1,0.01,0.01,0.01,0.01
mp,ex,1,2.1e11
mp,prxy,1,0.3
mp,dens,1,7800
rectng,0,1,-0.005,0.005
wpstyle,,,,,,,,1
wpstyle,0.05,0.1,-1,1,0.003,0,0,,5
wprota,0,90,0
asbw,1
wpstyle,,,,,,,,0
wpcsys,-1,0
esize,1/num      !单元尺寸
mshape,0,2D
mshkey,1
amesh,all
allsel
d,all,uz,,,,,rotx,roty      !约束面外平动和面内转动自由度
allsel
nsel,s,loc,x,0
nsel,r,loc,y,-0.005
d,all,ux,,,,,uy      !左端简支约束
nsel,s,loc,x,1
nsel,r,loc,y,-0.005
d,all,uy,,,      !右端铰支
allsel
finish
/solu
antype,modal
modopt,lanb,30,0,99999999,,off
mxpand,30,0,99999999
solve
finish
发表于 2013-8-2 11:08:49 | 显示全部楼层
ANSYS 汉化版(10.0,截图)
看看,这东西怎样!!
