查看: 6358|回复: 4
cfx计算报错求助~!!
发表于 2010-10-21 10:15:08 | 显示全部楼层 |阅读模式
计算有内冷通道的叶片换热,结果计算出现一下错误,请版上大牛们帮忙分析一下吧~非常感谢!!
    Job Information                           |
Run mode:       parallel run (MPI)
Host computer:  LYNCHSUE
Par. Process:   Master running on mesh partition:       1
Solver Build:   Thu Oct 15 00:45:24 GMTDT 2009
Attributes:     single-int32-64bit-novc8-noifort-novc6-optimised-su...
Job started:    Thu Oct 21 10:18:53 2010
Par. Process:   Slave  running on mesh partition:       2
Par. Process:   Slave  running on mesh partition:       3
Par. Process:   Slave  running on mesh partition:       4
|        Memory Allocated for Run  (Actual usage may be less)        |
Allocated storage in:    Kwords
                          Words/Node
                          Words/Elem
                          Kbytes
                          Bytes/Node
Partition | Real       | Integer    | Character| Logical  | Double
         1 |   404923.8 |   140889.0 |   3951.7 |     65.0 |   1208.0
           |     221.67 |      77.13 |     2.16 |     0.04 |     0.66
           |     260.62 |      90.68 |     2.54 |     0.04 |     0.78
           |  1581733.4 |   550347.8 |   3859.0 |     63.5 |   9437.5
           |     886.69 |     308.51 |     2.16 |     0.04 |     5.29
         2 |   405476.8 |   137601.3 |   3951.7 |     65.0 |   1208.0
           |     224.46 |      76.17 |     2.19 |     0.04 |     0.67
           |     261.43 |      88.72 |     2.55 |     0.04 |     0.78
           |  1583893.8 |   537505.1 |   3859.0 |     63.5 |   9437.5
           |     897.82 |     304.68 |     2.19 |     0.04 |     5.35
         3 |   416227.2 |   136658.2 |   3951.7 |     65.0 |   1208.0
           |     225.01 |      73.88 |     2.14 |     0.04 |     0.65
           |     265.05 |      87.02 |     2.52 |     0.04 |     0.77
           |  1625887.6 |   533821.1 |   3859.0 |     63.5 |   9437.5
           |     900.05 |     295.51 |     2.14 |     0.04 |     5.22
         4 |   412619.9 |   145559.1 |   3951.7 |     65.0 |   1208.0
           |     224.78 |      79.29 |     2.15 |     0.04 |     0.66
           |     265.24 |      93.57 |     2.54 |     0.04 |     0.78
           |  1611796.4 |   568590.1 |   3859.0 |     63.5 |   9437.5
           |     899.11 |     317.18 |     2.15 |     0.04 |     5.26
     Total |  1639247.8 |   560707.6 |  15806.7 |    260.0 |   4832.0
           |     271.87 |      92.99 |     2.62 |     0.04 |     0.80
           |     292.06 |      99.90 |     2.82 |     0.05 |     0.86
           |  6403311.0 |  2190264.0 |  15436.2 |    253.9 |  37750.0
           |    1087.48 |     371.97 |     2.62 |     0.04 |     6.41
|                     ****** Notice ******                           |
| Wall Heat Transfer Coefficient written to the results file uses    |
| "Wall Adjacent Temperature" for the bulk temperature.  If you want |
| to override the bulk temperature then set the expert parameter     |
| "tbulk for htc = <value>"                                          |
|                          Mesh Statistics                           |
| Domain Name          | Orthog. Angle | Exp. Factor  | Aspect Ratio |
|                      | Minimum [deg] |   Maximum    |    Maximum   |
| dcut 4               |       45.1 ok |        26  ! |        11 OK |
| duct 1               |       30.0 ok |        17 ok |         9 OK |
| duct 2               |       27.8 ok |        40  ! |        19 OK |
| duct 3               |       35.9 ok |        18 ok |         5 OK |
| passage              |       40.0 ok |       244  ! |       303 ok |
| trail                |       71.9 OK |         1 OK |         5 OK |
| blade                |       29.9 ok |        38  ! |        45 OK |
| Global               |       27.8 ok |       244  ! |       303 ok |
|                      |  %!  %ok  %OK | %!  %ok  %OK | %!  %ok  %OK |
| dcut 4               |   0   <1  100 | <1    1   99 |  0    0  100 |
| duct 1               |   0    3   97 |  0   <1  100 |  0    0  100 |
| duct 2               |   0   11   89 | <1    2   98 |  0    0  100 |
| duct 3               |   0   <1  100 |  0   <1  100 |  0    0  100 |
| passage              |   0    2   98 |  1    3   96 |  0    1   99 |
| trail                |   0    0  100 |  0    0  100 |  0    0  100 |
| blade                |   0    1   99 | <1    2   98 |  0    0  100 |
| Global               |   0    3   97 | <1    2   98 |  0   <1  100 |
44blade_04_003.rar
8.66 KB, 下载次数: 284
 楼主| 发表于 2010-10-21 10:15:25 | 显示全部楼层
Domain Name : dcut 4
     Total Number of Nodes                                =      997632
     Total Number of Elements                             =      955930
         Total Number of Hexahedrons                      =      955930
     Total Number of Faces                                =       82742
Domain Name : duct 1
     Total Number of Nodes                                =      890190
     Total Number of Elements                             =      852344
         Total Number of Hexahedrons                      =      852344
     Total Number of Faces                                =       75092
Domain Name : duct 2
     Total Number of Nodes                                =      762930
     Total Number of Elements                             =      729916
         Total Number of Hexahedrons                      =      729916
     Total Number of Faces                                =       65560
Domain Name : duct 3
     Total Number of Nodes                                =      653400
     Total Number of Elements                             =      624146
         Total Number of Hexahedrons                      =      624146
     Total Number of Faces                                =       57950
Domain Name : passage
     Total Number of Nodes                                =     1547440
     Total Number of Elements                             =     1469854
         Total Number of Hexahedrons                      =     1469854
     Total Number of Faces                                =      154672
Domain Name : trail
     Total Number of Nodes                                =       57600
     Total Number of Elements                             =       43120
         Total Number of Hexahedrons                      =       43120
     Total Number of Faces                                =       26600
Domain Name : blade
     Total Number of Nodes                                =     1120356
     Total Number of Elements                             =      937340
         Total Number of Hexahedrons                      =      937340
     Total Number of Faces                                =      355410
Global Statistics :
     Global Number of Nodes                               =     6029548
     Global Number of Elements                            =     5612650
         Total Number of Hexahedrons                      =     5612650
     Global Number of Faces                               =      818026
Domain Interface Name : blade duct 1
     Discretization type                                  =         GGI
     Intersection type                                    = Partitioner
     Non-overlap area fraction on side 1                  =    2.15E-05
     Non-overlap area fraction on side 2                  =    8.28E-06
Domain Interface Name : blade duct 2
     Non-overlap area fraction on side 1                  =    4.24E-06
     Non-overlap area fraction on side 2                  =    1.04E-05
Domain Interface Name : blade duct 3
     Non-overlap area fraction on side 1                  =    7.40E-06
     Non-overlap area fraction on side 2                  =    8.16E-05
Domain Interface Name : blade duct 4
     Non-overlap area fraction on side 1                  =    3.00E-06
     Non-overlap area fraction on side 2                  =    3.71E-06
Domain Interface Name : blade rib1
     Non-overlap area fraction on side 1                  =    5.11E-05
     Non-overlap area fraction on side 2                  =    3.94E-05
Domain Interface Name : blade rib2
     Non-overlap area fraction on side 1                  =    0.00E+00
     Non-overlap area fraction on side 2                  =    5.08E-07
Domain Interface Name : blade rib3
     Non-overlap area fraction on side 1                  =    1.24E-05
     Non-overlap area fraction on side 2                  =    1.40E-05
Domain Interface Name : blade rib4
     Non-overlap area fraction on side 2                  =    2.20E-05
Domain Interface Name : blade trail
     Non-overlap area fraction on side 1                  =    8.72E-05
     Non-overlap area fraction on side 2                  =    5.99E-05
Domain Interface Name : duct 2 rib
     Non-overlap area fraction on side 1                  =    5.69E-02
     Non-overlap area fraction on side 2                  =    1.88E-04
Domain Interface Name : duct 3 rib
     Non-overlap area fraction on side 1                  =    5.70E-04
     Non-overlap area fraction on side 2                  =    4.32E-04
 楼主| 发表于 2010-10-21 10:15:31 | 显示全部楼层
Domain Interface Name : duct 4 rib
     Non-overlap area fraction on side 1                  =    4.26E-04
     Non-overlap area fraction on side 2                  =    4.50E-04
Domain Interface Name : duct 4 trail
     Non-overlap area fraction on side 1                  =    1.27E-03
     Non-overlap area fraction on side 2                  =    4.92E-05
Domain Interface Name : duct1 rib
     Non-overlap area fraction on side 1                  =    1.48E-03
     Non-overlap area fraction on side 2                  =    7.49E-04
Domain Interface Name : pass blade
     Non-overlap area fraction on side 1                  =    4.12E-04
     Non-overlap area fraction on side 2                  =    4.15E-04
Domain Interface Name : pass trail
     Non-overlap area fraction on side 2                  =    1.49E-05
Domain Interface Name : per
     Non-overlap area fraction on side 1                  =    1.01E-03
     Non-overlap area fraction on side 2                  =    2.00E-03
| ERROR #001100279 has occurred in subroutine ErrAction.             |
| Floating point exception: Invalid number                           |
| Stopped in routine C_FPX_HANDLER:                                  |
|                An error has occurred in cfx5solve:                 |
| The ANSYS CFX solver exited with return code 1.   No results file  |
| has been created.                                                  |
End of solution stage.
| The following user files have been saved in the directory          |
| F:\lynchsue\Blade 2\Slove\44\44blade_04_003:                       |
| mon        |
This run of the ANSYS CFX Solver has finished.
发表于 2010-10-26 01:36:42 | 显示全部楼层
因为计算还没有开始,应该是网格的问题.
先用单程计算试试,如果马上报错, 肯定是网格的问题.如果可以进入计算阶段,网格应该还好.
重新生成个网格试试,有时候随便改变网格几个参数设置,就可以计算了
发表于 2013-7-11 00:32:32 | 显示全部楼层
好像是网格大小的原因,可以把网格做大点试试。我是这么解决的。
