查看: 3572|回复: 1
弱弱问一下柴油机燃油材料设置问题
发表于 2012-9-3 09:35:26 | 显示全部楼层 |阅读模式
请问柴油diesel fuel材料怎么设置,可以用C12H26代替不?如果不行该怎么设置?
发表于 2012-9-29 11:50:01 | 显示全部楼层
如果是star-cd 4.18 用ECFM-CLEH模型,可以选择柴油作为燃料(如下:)
The ECFM-CLEH combustion model has been re-formulated for increased accuracy and reliability, both in terms of the model thermodynamics and of pollutant emission estimation. Diesel, Gasoline and N-heptane fuel types are now
available for use with this model (see Chapter 11, “The ECFM-CLEH model” in the Methodology volume).
如果是较低的版本,建议用C12H26代替柴油...
